Hi Taimur,
First of all, we need non-zero value of AS, AD, PS, PD, NRS, NRD. It tends to transient non-convergence for some circuits if those values are zero.
Second, we depend on schematic entry software and good PDK to calculate those parameters automatically nowadays. I say good PDK because not all foundries provide PDK that calculate those parameters or calculate those parameters correctly.
Third, even if you have a schematic entry software and good PDK, you cannot always rely on them. For example, the MOSFETs in I/O cells may have very large drain diffusion to meet ESD design rule. It causes bigger non-linear parasitic capacitance, please be careful if you design a very high performance circuit.
Fourth, if unfortunately you do not have any schematic entry software and PDK. There is some parameters in the MOSFET model for estimation of the area and perimeter of drain and source. For BSIM3, there are hdif and ldif, acm and so on. Please read simulator manual, and model manual for details.
The last, you'd better to check your SPICE/Spectre model before you begin to simulate.
Best Regards, Yawei
