Jul 31st, 2024, 3:21am
Pages: 1 2
Crude current reference circuit (Read 12778 times)
RobG
Bozeman, MT
Re: Crude current reference circuit
Reply #15 - Dec 07th, 2010, 5:41am
Isabelle wrote on Dec 7th, 2010, 3:07am:
The simplest solution might be to connect the available bandgap voltage directly to a PMOS device with a really small W/L ratio to lower its gm.  Since the AnalogDE's accuracy requirements are very loose, that may be good enough, even with PVT variations..... Smiley
Hi Isabelle,
Yes, that has been suggested by Carl and myself (but I suggested an NMOS). I'm curious how you or Carl would connect the PMOS. With an NMOS it is simple: Gate to Vref, and source to GND, and take the current from the drain. But how would you connect a PMOS?
rg
Frank Wiedmann
Munich, Germany
Reply #16 - Dec 7th, 2010, 6:32am
Is it just me who finds it strange that Isabelle's contribution is an exact quote from carlgrace (reply #3) and that there is a link to a "Dogs for sale" website in her signature? Ken?
RobG
Bozeman, MT
Reply #17 - Dec 7th, 2010, 6:35am
Frank Wiedmann wrote on Dec 7th, 2010, 6:32am:
LOL... you are correct
carlgrace
Berkeley, CA
Reply #18 - Dec 7th, 2010, 4:23pm
I am so honored that my suggestion could be used by Isabelle in her spam.
carlgrace
Berkeley, CA
Reply #19 - Dec 7th, 2010, 4:27pm
RobG wrote on Dec 7th, 2010, 5:41am:
Hi Isabelle,
rg
Rob,
It totally depends on the VDD range and whether AnalogDE needs to source or sink a current.  For example, if the BG voltage is 1.1 V, for instance, it might be challenging to keep an NMOS under control with such a large VGS.  If VDD where 1.8 V, for instance you could connect it like you suggested AnalogDE connect the NMOS: Vref to gate, source to VDD, drain to load.  Either way works, depending on the situation.
AnalogDE said the plan was to go with the weak NMOS.  I think it will work.
RobG
Bozeman, MT
Reply #20 - Dec 8th, 2010, 7:26am
carlgrace wrote on Dec 7th, 2010, 4:27pm:
Hi Isabelle,
rg
Rob,
Oh, ok. I don't like doing stuff like that (even though it was strongly endorsed by a lady selling dogs Smiley ). The reason is that Vref is bypassed to ground so any AC power supply noise appears across the PMOS gate/source and gets put onto the current (Iac=gm*Vnoise). Most applications can handle the variation with Vdd, but not the AC noise, especially when mismatches are considered.
The larger Vgs is actually an advantage since it lowers the gm. It also steers the temp co towards PTAT, which is better for most circuits. There is also a point where the temp co is zero. This point has been around Vgs=1.2 V when I've played with it, although I'm sure it depends on the Vt of the device.
Adding resistive degeneration decreases the gm even more.
That's my story, and I'm sticking to it  :P .
Rob
No I don't sell dogs.
mowiehowie
Reply #21 - Dec 8th, 2010, 10:18am
do you sell only raw dogs ? any hot dogs ?
carlgrace
Berkeley, CA
Reply #22 - Dec 8th, 2010, 1:13pm
RobG wrote on Dec 8th, 2010, 7:26am:
Hi Isabelle,
rg
Rob,
Rob
You're right Rob.  Your idea is the way to go.  I didn't think about the noise... I figured if AnalogDE had such a loose tolerance on the matching then most likely there wasn't a big requirement on the noise.  I do get your point.  Good luck getting the tempco hitting the match zero spot.  Reminds me of gm stages in RF circuits that try to hit the magical zero third-order distortion point.
Carl
PS I'm pretty sure Isabelle would have sold you a dog pre-cooked if you paid her enough...
Pages: 1 2
