Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 18
th
, 2024, 1:17pm
Home
Help
Search
Login
Register
PM to admin
Simulators
Circuit Simulators
› How to get data of stb analysis in calculator?
Previous topic
Next topic
How to get data of stb analysis in calculator? (Read 2784 times)
Dec 03
rd
, 2010, 1:29am
Hi Guys,
How do I get the data of stb analysis in calculator. I want to measure the phaseMargin, gainMargin using the functions in calculator. Since I have to run a lot of corners, obviously it is not an efficient way to record stability summary in
Direct Plot
Main Form
stb
form.
Yawei
IP Logged
Re: How to get data of stb analysis in calculator?
Reply #1 -
Dec 3
rd
, 2010, 2:18am
Yawei,
From the Results Browser, RMB click on the parameter you want: gain
margin, phase margin, ... and send it to the Calculator. Once it is in the
Calculator you can save it to an output.
IP Logged
Frank Wiedmann
Munich, Germany
Reply #2 -
Dec 3
rd
, 2010, 3:51am
Another possibility is to select the "Add To Outputs" button in the Direct Plot form. You can then look up the corresponding expressions in ADE with Setup -> Outputs and manually copy them to the calculator.
IP Logged
Reply #3 -
Dec 4
th
, 2010, 3:44am
Hi Sheldon and Frank, I got it. Thank you.
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
- Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
»» Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
