Jul 19th, 2024, 12:23pm
Envelope sim time limits? (Read 1944 times)
wave
Dec 07th, 2010, 4:50pm
Hi all -
I'm running Envelope Analysis, looking at Voltage vs Time.
ADE 5.10.41.500.6.134
When I run a relatively short  Stop Time of 1mS, things work OK.
Waveforms plot OK; perhaps 7 baseband cycles.
When I run longer sims (10-20mS), there is NO output.
ADE, Direct Plot Form, acts as if the data wasn't saved;
yet there are huge output files:  envlp.fd/dt.envlp
Since I'd like to sim slowly incrementing dynamic waveforms, this is a limitation.
Any thoughts?
thanks,
Wave   Cool
Re: Envelope sim time limits?
Reply #1 - Dec 14th, 2010, 6:26am
Can you start wavescan stand-alone and browse to those output files?  This might tell you whether the problem is ADE or the files.
Reply #2 - Jan 2nd, 2011, 2:22am
Which version of the simulator is being used? Are you using harmonic balance or shooting? How big are the files (do an ls -l on the directory and post the results).
Not sure I can immediately think of a good reason for a problem, but the above might provide enough pointers to pinpoint the problem.
