Jul 31st, 2024, 1:24am
opamp/bias from CMFB (Read 99 times)
ontheverge
Dec 07th, 2010, 8:42pm
In designing opamp circuit, is it desirable to bias output common mode different from target Vout_CM to have consistent feedback current to the input pairs, or should ckt be biased so that Vout_cm is almost the same as its target value, what are the considerations here?
thanks,
Steve
raja.cedt
Re: opamp/bias from CMFB
Reply #1 - Dec 7th, 2010, 10:21pm
try to keep same but across corners it might be tough, but whatever the designed common mode , CMFB loop will try to make it equal to Vref just by introducing systematic offset.
Thanks.
carlgrace
Berkeley, CA
Reply #2 - Dec 8th, 2010, 1:15pm
Echoing what Raja said, usually the desired common-mode level is a the point of maximum swing, and generally it is a convenient voltage to generate.  (for example, sometimes it is mid-supply).  But, it really doesn't make much difference because the feedback loop will take care of any offsets.
