Jul 30th, 2024, 11:30am
Cascode Bias (Read 7333 times)
extremis
Cascode Bias
Dec 13th, 2010, 6:51am
I have replaced the 2nd stage of the classic 2 stage Miller compensated OPAMP with a cascode stage to get more gain, i have BIASed the top 3 MOS transistors to work at saturation for Vcm=VDD/2, but they get out of saturation range for higher/lower Vcm.
What is the best way to make it work for the entire Vcm range? Should i use a wide swing cascode mirror?
Thank you in advance for any suggestions.
AnalogDE
Re: Cascode Bias
Reply #1 - Dec 13th, 2010, 10:42am
Are you using a telescopic topology?  If so, that topology has an inherently limited common mode input range -- consider using a folded cascode topology to increase VCM range.
extremis
Re: Cascode Bias
Reply #2 - Dec 16th, 2010, 9:00am
No, it is not telescopic topology; first stage is a differential PMOS pair with NMOS mirror load. Instead of the NMOS common source with PMOS load second stage i have a cascode stage, but it is much more unstable.
I design the OPAMP so that Vout=(VDD+VSS)/2 for Vcm=(Vcm,max+Vcm/min)/2; Vout usually varies with Vcm, but with this topology it varies so much that one of the middle transistors gets out of the saturation range.
AnalogDE
Re: Cascode Bias
Reply #3 - Dec 16th, 2010, 11:34am
Got a picture of your opamp?  You can't really control Vout with a high-gain amp unless you wrap feedback around it.
extremis
Re: Cascode Bias
Reply #4 - Dec 17th, 2010, 2:42am
I am trying this OPAMP from P.E. Allen lectures, except that input is a differential PMOS pair.
Lex
Eindhoven, Holland
Re: Cascode Bias
Reply #5 - Dec 17th, 2010, 2:59am
extremis wrote on Dec 17th, 2010, 2:42am:
If you change the input (differential pair) to PMOS, and leave the output the same, you can get into biasing problems. If u want PMOS in, PMOS out, go for the folded cascode.
You can also make a complete PMOS->NMOS translation: NMOS diffpair -> PMOS diffpair AND PMOS outputstage -> NMOS output stage.
extremis
Re: Cascode Bias
Reply #6 - Dec 17th, 2010, 3:25am
I have already done the PMOS->NMOS translation; it is the BIAS that bothers me. I have used a wide swing cascode mirror to BIAS the top 2 PMOS transistors, but maybe there is a better solution that works for the entire Vcm range. I have also used a voltage divider to avoid complementary differential input.
Lex
Eindhoven, Holland
Re: Cascode Bias
Reply #7 - Dec 20th, 2010, 1:23am
extremis wrote on Dec 17th, 2010, 3:25am:
Biasing of transistor N3 will be poor around corners. You can improve by using a long diode connected transistor with a resistor to supply, to bias N3. =)
