Sep 11th, 2024, 6:13pm
Deep Nwell needed for ADC? (Read 6927 times)
carlgrace
Berkeley, CA
Dec 17th, 2010, 3:16pm
Does anyone have any experience with deep nwell?  Does it really help much for, say, a 12b 80MSPS pipelined ADC?  I built one years ago in 0.25um CMOS without deep nwell.  Now I'm building another in 65nm but I would prefer not to use deep nwell so I can reduce layout size.  Do you guys think this is a mistake, or can I get away with it?
vivkr
Re: Deep Nwell needed for ADC?
Reply #1 - Dec 20th, 2010, 7:11am
carlgrace wrote on Dec 17th, 2010, 3:16pm:
it's difficult to say. there are 2 points which come to my mind:
1. Improved isolation against substrate noise: This is probably the big advantage, although I don't know how good the isolation remains as you go faster and faster. Obviously, you need to use good shielding.
2. Impact ionization: If you are planning on using folded cascode, maybe with gain boosting to cut down on power in the amps, then you may run into issues with impact ionization in the N-cascode. Deep Nwell technology allows you to use a local P-well for the NMOS, permitting you to tie B-S together and avoid the Rout degradation, but depending on the topology you choose, this may or may not be relevant.
You need to consider the cost-performance tradeoff. The only times I used Deep-Nwell was when I anyway needed it for some other reason, like HV support, or when the technology used anyway happened to have it.
Vivek
Reply #2 - Jan 22nd, 2011, 1:02pm
The deep N-Well concept (10um well) was introduced as a concept on IBM foundry processes. Buried inside IBM there was a study done (I initiated it about 8 years back) on how much these things help with noise isolation,.
Bottom line - its unique to the design and it helps a few dB but its not the savior of noise. With and without deep nwell isolation were used and the noise coupling differences on some test circuits was like 2-4 dB difference and sometimes it made no difference.
Not needed, use good design practices and be done with it.
Berti
Reply #3 - Jan 25th, 2011, 3:08am
Hi Jerry,
Are those 2-4dBs from the substrate isolation only?
I made the experience that coupling is often dominated by coupling between metal wires, pad-ring etc., and not the substrate.
Reply #4 - Jan 27th, 2011, 3:01pm
Berti wrote on Jan 25th, 2011, 3:08am:
Hi Jerry,
Yes - to pull all the other variables out of the equation the layouts were exact same everything - spacing routing, circuits etc, the ones with/without Deep Nwell tubs were just with/without the tubs, and bare substrate was left in place on some test cases, and then regeular depth Nwell was used in the third case (there was a bunch of different situations that all got tested.)
The report was not too widely published because at the time IBM thought they had something great in the deep nwell concept, and the reality of the matter was more along the lines of "it helps a few dB, but thats it" which is not what they wanted to hear.
I totally agree with you that there are som many other coupling paths that have not been accounted for.
Berti
Reply #5 - Jan 28th, 2011, 4:35am
Well, but that means the improvement of 2-4dB ïs for "substrate coupling"+"whathever else". The actual improvement which comes from the deep nwell might therefore be slightly higher than 2-4dB (even only slightly), as basically two sources are added ...
Reply #6 - Jan 28th, 2011, 4:46pm
the actual improvement seen from the use of Deep N well was 2-4 dB
I can not state it any more clearly than that
