Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Jul 29
th
, 2024, 3:20am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› 3.3V opamp design with 1.8V devices
Previous topic
Next topic
3.3V opamp design with 1.8V devices (Read 3343 times)
rampat
Dec 27
th
, 2010, 5:06am
Hi All
I need to design a opamp with 3.3V supply and only 1.8V devices are available from the process.How to take care of the reliability issues for the devices? If anyone knows solutions or any reference/papers to the above problem it will be a great help.
rampat
IP Logged
rfmagic
Re: 3.3V opamp design with 1.8V devices
Reply #1 -
Dec 27
th
, 2010, 7:29am
Telescopic configurationד seems the right choice for you as each transistor will take on some of the voltage to lower the stress form the 1.8V devices. On top of that you can get more gain due to the increased ouput impedances of the stacked stages.
IP Logged
AnalogDE
Reply #2 -
Dec 30
th
, 2010, 1:22am
You may also want to look into using a level shifter or regulator to level shift the supply down to around 1.8V.
IP Logged
nus_lin
Reply #3 -
Jan 15
th
, 2011, 7:02pm
the key point here is to design your circuit and set proper operation condition so that none of the Vgs or Vgd exceeds 1.8V, because the gate oxide is the most vunerable part. for diodes, the breakdown voltage should be larger than 3.3.
IP Logged
HdrChopper
Reply #4 -
Jan 17
th
, 2011, 4:47pm
As rfmagic suggested cascodes are the way to go, always taking care of not creating VGs voltages higher than 1.8v.
That way the 3.3v max operating voltage will be always split among at least to devices in series.
Best
Tosei
Keep it simple
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
