I don't understand - they're in the software installations. If you have access to the software installations (which surely you'll need to run the software), then you really should have access to the tutorials, unless somebody at the university has (bizarrely) locked them down (and they'd have had to go out of their way to do this). If that's the case, you should ask somebody at your University to fix it.
I cannot post bits of Cadence software or tutorial data freely on the web - these are provided under the software license.
