Jul 17th, 2024, 2:31am
how to load assert statements from ADE (Read 2164 times)
cristiano.azzolini
germany
Jan 05th, 2011, 9:21am
I find the Assert statements for Spectre language very useful for many run-time verification on the devices.
The only problem is that... how can I automatically add all my statement in the sim netlist generated by ADE ?
I tried to create a separate file and include that from the Model window but the assertions should be inserted in the netlist footer, not on top.
Any idea is appreciated!
Cristiano
Re: how to load assert statements from ADE
Reply #1 - Jan 5th, 2011, 1:18pm
Hi Christiano,
Why do the assert statements need to be included at the bottom? There should be no problem with including them at the top - spectre shouldn't care. So doing it via the model libraries form should be fine. Many customers have them as part of their model definitions, so I see no reason why this shouldn't work.
There's also the Device Check UI, but to be honest that's more for design-specific assertions (and actually I find it easier to write the spectre syntax than use the form for things like this).
cristiano.azzolini
germany
Reply #2 - Jan 6th, 2011, 11:34pm
Hi Andrew,
you are right, adding the assert file as a model is ok but I forgot to use a .scs extension in the filename so that I received some errors due to sintax misinterpretation.
Now it works correctly.
     Cristiano
