kelly
Hi, So my passive mixer drives a on chip IF VGA and has a 5p cap at the output for filtering. Thus, my input impedance is complex from 1G to 4G . There is going to be a on chip attenuator before the passive mixer. My questions are
1. can the attenuator has a ZL that is not only differernt from Zin but also complex? If it can, does that make the attenuator design a lot more comlex? 2. Will my best approach still be trying to make the mixer Zin look like a real resistor? Is that possible with an capacitive load at the IF port and do this for pretty broad band?
I guess to sum up my questions, what's the best approach in dealing with the attenuator/passive mixer interface?
Thanks.
