Jul 17th, 2024, 11:32am
RF Power Amplifier IC (Read 3329 times)
themaccabee
Jan 12th, 2011, 2:00am
This is about a wide band integrated RF Power Amplifier
I was going through the data sheet of MWE6IC9100N & seen the two application notes mentioned i.e. AN1977 & AN1987.
I believe that the MWE6IC9100N includes a thermal tracking circuit inside consisting of a tracking FET .And this FET when supplied by a constant Vg in series with a RESISTOR will regulate the IDQ of the RF FET over temperature variations.
May be this is silly but I've a following doubt for you,
My question is that in addition to the internal thermal tracking FET system supplied by a constant VG through a series RESISTOR , is it necessary to have an additional bias control circuitry( Active bias compensation controller or current source bias controller) mentioned in AN1987 for MWE6IC9100N if we are intending to operate it over a range operating temperatures.If needed then why exactly is so?
Any help will be greatly appreciated
Thanks & Regards
« Last Edit: Jan 12th, 2011, 7:41pm by themaccabee »
Re: RF Power Amplifier IC
Reply #1 - Jan 22nd, 2011, 12:44pm
you need to contact the product engineering support group for the IC.
wrong forum
feng lau
Reply #2 - Feb 17th, 2011, 6:55pm
Amplifiers have a quiescent operating point which will be affected by temperature changes.If amplifier is using in a very wide temperature range, its queescent operating point is changed with temperature.And the amplifter maybe work in a wrong conditions. It is necessary to have an additional temperature compensation circuit as AN1977 & AN1987 give out. Smiley
View Profile feng lau   IP Logged
