themaccabee
This is about a wide band integrated RF Power Amplifier
I was going through the data sheet of MWE6IC9100N & seen the two application notes mentioned i.e. AN1977 & AN1987.
I believe that the MWE6IC9100N includes a thermal tracking circuit inside consisting of a tracking FET .And this FET when supplied by a constant Vg in series with a RESISTOR will regulate the IDQ of the RF FET over temperature variations.
May be this is silly but I've a following doubt for you,
My question is that in addition to the internal thermal tracking FET system supplied by a constant VG through a series RESISTOR , is it necessary to have an additional bias control circuitry( Active bias compensation controller or current source bias controller) mentioned in AN1987 for MWE6IC9100N if we are intending to operate it over a range operating temperatures.If needed then why exactly is so?
Any help will be greatly appreciated Thanks & Regards
