Jul 17th, 2024, 1:41pm
Error using NPORT (Read 606 times)
melbadry
Error using NPORT
Jan 30th, 2011, 6:07pm
I am trying to use nport to use for tabulated s-parameters with 8 ports. The file is in touchstone format. When I try to simulate I get the following error:
Error found by spectre during circuit read-in.
   ERROR (SFE-874): "input.scs" 23: Unexpected keyword "options". Expected equals.
Is there a work-around for this problem?
I am using cadence 6.1.3 with mmsim version 6.2
Re: Error using NPORT
Reply #1 - Jan 31st, 2011, 5:21am
Melbadry,
  It is not clear what the issue is from the post. If you check the
nport help, options is not mentioned. The message does not appear
to be related to the nport.
    spectre -h nport | grep options
Could you post line #23 from your netlist?
