Jul 17th, 2024, 5:40pm
load impedance with sp analysis (Read 1921 times)
vp1953
Feb 02nd, 2011, 10:29am
I was wondering why using sp analysis (Cadence spectreRF), the simulated small signal load impedance changes with the port impedance. Since the load is the same, the simulated impedance should be the same regardless of what the port impedance is.
rfidea
Europe
Re: load impedance with sp analysis
Reply #1 - Feb 3rd, 2011, 12:42am
I tested this in Analog Artist, IC6.1. When I tried to plot S11 I only managed to plot different versions of S11 (mag, phase, dB, real, Smith ...). I do not think you can plot the input impedance of the DUT directly from the sp analysis. I guess my question is how have you plotted the impedance?
Of course you can do some math of the S11 data to get that, but in that case it seems easier to do an AC analysis and measure input voltage and current and take it from there.
vp1953
Reply #2 - Feb 3rd, 2011, 10:36am
Hi RFIDEA,
The S11 will obviously change with port impedance(Z0)since |S11|=|Zl-Z0/Zl+Z0|
But the load impedance itself should not change - when you plot after SP analysis in Cadence Spectre, choose ZP (in the plot options)and this should give the impedance.
vp1953
Reply #3 - Feb 3rd, 2011, 2:22pm
Hi Pancho,
Thanks for pointing it out. My simulation has only one port (there is no Z12 term) so ZP should give the input impedance. Do you agree?
rfidea
Europe
Reply #4 - Feb 4th, 2011, 12:03am
Hi vp!
Thanks for the tips of zp and zm. I tried it out this morning and get it to work. Even if I change the port impedance I get the same load impedance if I select ZP and the plot the real and imaginary part. I'm using a very new ADE version, 6.1.5. Do you using an old version which has a bug in it?
I agree with your statement that ZP=ZM if you only have one port. Even if you have two ports but good isolation between them the results should be the same. See Wikipidia definition of z-parameters
http://en.wikipedia.org/wiki/Impedance_parameters
vp1953
Reply #5 - Feb 4th, 2011, 2:04pm
Hi Rfidea,
Thanks for your analysis. I think i know what the problem is - the impedance really depends on the circuit that you are looking at. In my case, I was looking at a schottky diode based charge pump. Changing the port impedance changes the amplitude of the RF signal at the chip front-end and since the front-end is highly nonlinear, it shows a different impedance.
rfidea
Europe
Reply #6 - Feb 5th, 2011, 1:00am
Hi vp!
A non-linear input should give you this behavoural, for sure. But that was maybe not obvious from the beginning...
rfidea
Europe
Reply #7 - Feb 5th, 2011, 1:32am
Yeah, I agree. Even if the non-linear effect is there it should only change the large-signal behavoural. Since SP is a small-signal analysis we should not see the effect there. You are right.
I was thinking of one other explaination. VP has an input with a charge pump structure. If there is a feedback at the input defining the input impedance and the port impedance is part of the feedback network, we should get this effect.
vp1953
Reply #8 - Feb 5th, 2011, 8:44am
HI Pancho,
Quote:
Unless Port change DC operation point, port impedance never affects input impedance measurement even if port impedance is part of the feedback network.
The circuit is essentially a rectifier circuit (a voltage hextupler) with no dc voltages present other than the ones that are rectified from the incoming RF signal. The steady state DC values at different points of the circuit are very dependent on the incoming RF signal
vp1953
Reply #9 - Feb 6th, 2011, 10:45am
Hi Pancho,
I just checked again and the measured load impedance does change with the port impedance.
I used a capacitor coupled diode connected nmos as my test circuit (in general some sort of a rectifying circuit is needed to see this effect). First i measure the input impedance usig 50 ohm source and the measured impedance is 8-j500.
Then i use port impedances of 8 ohms and 8+j500 to measure the impedance of the test circuit and the load impedance changes each time. Not surprising as there is almost a 40x increase in the amplitude of the voltage at the test circuit between the two port impedances so some change in impedance is to be expected.
