kapil soni
Nagpur (India)
Thank you sir for reply ..... In this PDF the IF and LO port connect with VCVS and i cant analysis of S22(IF), S33(LO) than how am i ensure that output is matched to 50 Ohm. I did PSP aith PSS analysis in cadence for S-Parameter analysis. I matched RF at 50 Ohm and got S21 is 4dB when i connect simple port at IF with a capacitor without VCVS but in this case IF port not perfect matched, but when i use VCVS at the IF my S21(gain) increase 20dB. Is it correct. help me some one its urgent to me..
Thank you kapil soni
