Hi Peter,
Currently you have to use the opParamExprList property in the simInfo for the simulator you want, to map the lower level data to the higher level. I suggest you search for opParamExprList in cdnshelp to find out how to do it.
Hopefully we'll be doing something to avoid the need to modify the CDF to do this, but for now, this is really the only way.
