Sep 11th, 2024, 10:10am
why should be metal layers in alternate directions? (Read 2832 times)
seahs
Feb 11th, 2011, 11:24pm
For example, if metal 2 is horizontal and metal 3 should be vertical.
Is it because of parasitic capacitance?
rfidea
Europe
Re: why should be metal layers in alternate directions?
Reply #1 - Feb 12th, 2011, 12:31am
No, it is just a way for simplify routing. It is not by a coincident it is called Manhattan routing. (Except for Broadway that is...)
Reply #2 - Feb 13th, 2011, 1:39pm
Mostly its for simple routing, alternate N-S paths with E-W paths. (or up-down, left right)
Consequently, if you want to go anywhere on the chip, in theory, you only need to go thru one set of vias.
The reality of the matter is that lower metal layers tend to be used for routing inside a functional block, and upper metals get used between blocks in the system.
Vertical thickness of oxides is intentionally kept thick to minimize coupling between vertical layers, but some coupling does exist nonetheless.
love_analog
Reply #3 - Mar 3rd, 2011, 11:39am
Another reason is to prevent coupling. If M2 is horizontal and M3 is also horizontal and right on top of M2, you could capacitive coupling between the 2 metals.
loveanalog.blogspot.com
The Power of Analog
