Jul 27th, 2024, 11:34pm
Flip flop design (Read 4463 times)
haykp
Flip flop design
Feb 14th, 2011, 3:13am
Dear Forum,
The attached picture is a schematic diagram of a Dff.
As can be seen in that diagram the first input TG clock is CL and not CLK.
What is the reason of this? Why we cannot conect the CLK to the clock of first TG.
Hayk Petrosyan
rfidea
Europe
Re: Flip flop design
Reply #1 - Feb 14th, 2011, 9:51am
Probably to get some buffering and not loading CLK more than necessary.
Rakesh
Reply #2 - Feb 14th, 2011, 10:57am
Probably for meeting hold time requirements or bufferening the input clock
vp1953
Reply #3 - Feb 15th, 2011, 9:09am
Hi Haykp,
You are saying CLK and CL could be used instead of CL and CL-bar. The circuit requires complementary clock signals. CLK is external and may have a large skew depending on the load on the driver; i dont know if there might be some issues using a skewed CLK and a non-skewed CL for the complementary clock signals. Using internally generated CL and CL-bar removes the external clock skew.
Nandish Mehta
Reply #4 - Feb 21st, 2011, 8:23am
The main concern with all flip-flop design is the clock loading. It is one of the main design metric.
CLK routing and distribution tree already consumes hell lot of power. Add even one TG extra to CLK is majority of time not affordable. Hence CL & CLb are generated first.
If you go through the operation you will find that operation of F/F is still same as with CL or CLK.
Hope this helps
Nandish
