Hi DUDE,
I would like use this PA as a final stage and drive the athena. If I using a square source drive the PA directly without input matching, is the PAE result got from spectreRF's PSS simulation meaningful?
RFICDUDE wrote on Feb 22nd, 2011, 4:25am:I guess your question depends on how you intend to use the amplifier?
If you are going to design a driver stage to drive the final stage, then no you do not need to impedance match to the source. More importantly, you shouldn't try to use a 50ohm source, rather you should use something that is more representative of the circuit you intend to drive the final stage with.
The test signal should be square for testing the switching performance, but you are also going to need something like a pulse width modulated squarewave test signal to test the linearity of the Class-D amplifier (i.e. switching efficiency alone is not sufficient).
