Aug 16th, 2024, 1:26pm
Metal layers in layout (Read 10893 times)
saam
india
Mar 01st, 2011, 1:59am
Can anyone tell me ..why top metal layers in layout having high resistance compare to lower,,is there any analysis for this??
ThankU
saam
raja.cedt
Re: Metal layers in layout
Reply #1 - Mar 1st, 2011, 6:43am
no top metals are always have less res because of its thickness and this is the reason why inductors have been made with top layers.
Thanks.
Lex
Eindhoven, Holland
Reply #2 - Mar 1st, 2011, 8:05am
Not always true Raja. Some processes have copper at the bottom and alu and the top.
saam
india
Reply #3 - Mar 2nd, 2011, 7:56pm
Thank U for reply
    But can u elaborate more, means in terms of analysis like using sheet resistance or resistance formula.
also can u give me any materials,books or any links  regarding how to use metal layers in layout
Thanku
saam
Reply #4 - Mar 3rd, 2011, 8:58am
Metal layer thickness, metal used, oxide thickness between layers, are all able to be defined and selected by whoever defines and creates the foundry process.
Commonly used conventions are:
- Top layer is often thicker metal.
- Oxides are thick between layers (lower C coupling)
However, its all unique to the foundry process you are on.
love_analog
Reply #5 - Mar 3rd, 2011, 10:58am
Alexander,
Why would anyone flip the metal layers. The whole point of putting copper was to increase EM reliability. I would think the top layer metals would always carry more current since they are carrying it from the pads.
loveanalog.blogspot.com
The Power of Analog
Lex
Eindhoven, Holland
Reply #6 - Mar 4th, 2011, 5:01am
love_analog wrote on Mar 3rd, 2011, 10:58am:
Alexander,
Circuits that benefit from a thinner stack use copper at the bottom as copper can be thinner in height.
saam
india
Reply #7 - Mar 6th, 2011, 1:39am
ThankU for replies..
         can anyone provide materials, books or any links regarding metal routing in analog layout.
waiting
saam
saam
india
Reply #8 - Mar 6th, 2011, 8:46pm
Can anyone tel me ..Why top metal layer (M8) has low resistance compare to bottom (M1) ???
ThankU
saam
ACWWong
Oxford, UK
Reply #9 - Mar 7th, 2011, 4:42am
Maybe its thicker or of a different material. Check your process manual for data.
For formulae on resitivity just google it.
For methods of layout, Alan Hasting's book Art of Analog Layout is good.
saam
india
Reply #10 - Mar 8th, 2011, 9:30pm
Thank You ACWWong...i wl
rfmagic
Reply #11 - Mar 9th, 2011, 6:22am
Hi saam,
As most of the guys have mentioned, the first thing you have to do is to find out the process paremeters of your foundry. Then you can start
estimating the zero order parasitics of the layout i.e. comulative sheet resistance, cumulative capacitance of the traces and inductance of the metal layers. this can help you get started.
I have created a simple spreadsheet a long time ago that does these simple calculations and you may find it useful.
Enjoy.
Reply #12 - Mar 10th, 2011, 10:48am
Alexander,
Increase EM reliability?
Total news to me, and I was involved with the Cu CMP process at the time.
Copper got added to drop the R down, to get faster RC time constants to allow higher clocking rates.
Jerry
Reply #13 - Mar 10th, 2011, 10:52am
saam wrote on Mar 6th, 2011, 8:46pm:
ThankU
saam
Unique to process as others have stated, but commonly its because they make the top layer thicker.
If its all copper CMP layers, you have very good control over the characteristics of the layer thickness.
The PDR's are fussy so that you can avoid cupping/dishing issues, when doing the CMP planarization of the layers.
saam
india
Reply #14 - Mar 20th, 2011, 10:40pm
Thank you for all...:) for such a great discussion
