Jul 16th, 2024, 9:45am
bidirectionnal switch with wreal inout in VAMS (Read 5391 times)
idriss
Mar 04th, 2011, 5:02am
Hi Guys
I would like to model a Switch in verilogams using wreals,
I have 2 inouts wreals A and B, with an On and the thing is the switch is bidirectional, it means the signal can go from A to B or from B to A, in verilog you have specific function to do that, but for wreal is someone knows  or have an idea how to that?
Thank you very much
Idris
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: bidirectionnal switch with wreal inout in VAMS
Reply #1 - Mar 7th, 2011, 7:21am
Hi Idriss,
The big difference between normal Verilog signals and wreal is that there is no standard resolution function for wreal. Cadence has created a few proprietary extensions that can help you to make bidirectional wreal ports.
module switch(a, b, s);
  inout a, b;
  input s;
  wreal a, b;
  wire s;
  real sigA, sigB;
  always @(a or b or s) begin
    sigA = a;
    sigB = b;
    if (s == 1'b1)
	case (1)
	(a === `wrealZState && b !== `wrealZState)
	  sigA = b;
	(a !== `wrealZState && b === `wrealZState)
	  sigB = a;
	endcase
  assign a = sigA;
  assign b = sigB;
This is the general idea, anyway. I have not actually tested the above code, I'll leave that up to you. The whole point here is that the special symbols `wrealZState and `wrealXState are used to make the wreals behave similar to other four-state logic in Verilog.
Cheers,
Marq
