Aug 16th, 2024, 1:20pm
LNA at Ku band (Read 1582 times)
jayce3390
LNA at Ku band
Mar 07th, 2011, 10:25am
I need to design a LNA in the Ku frequency band (close to 14 GHz). I would like to use discrete  packaged pHEMT transistor which could be mounted with PCBs.
My question is :
If I make the choice to go with non MMIC process, what is the best laminate I should use to design my hybrid LNA?
Smiley
rfcooltools.com
Re: LNA at Ku band
Reply #1 - Apr 1st, 2011, 12:32pm
jayce3390,
The most common laminate is probably a two layer Rogers 4003c.  Which is used in almost almost all satellite TV LNB's.  Its cheap and thermally stable.
http://rfcooltools.com
