Jul 16th, 2024, 11:51am
[Help] error on simulation about verilogA block (Read 4274 times)
Patrick520
Hong Kong
Mar 08th, 2011, 1:19am
Hi. I am new to Cadence IC5141. I am doing a simple simulation. I use Cadence IC5141 on RHEL5.4.
I use model writer to write a delay cell, the verilogA code is listed here:
`include "discipline.h"
`include "constants.h"
module delay_elem (vin, vout);
input vin;
output vout;
electrical vin, vout;
parameter real td = 1.0n from (0:inf);
analog begin
V(vout) <+ absdelay(V(vin), td );
And I use a pulse source from analogLib to give this delay cell pulses. And the delay cell is connected to a 50ohm resistor. I use the ADE (spectre) to simulate the cell.
I chose tran analysis.
However, there is error here:
Error found by spectre during circuit read-in.
"input.scs " 9 :Top-level parameter 'm' must be initialized with a value or expresstion.
Warning from spectre during circuit read-in.
"input.scs" 10: parameter name 'm' is researved for the subcircuit multiplicity factor. So a formal parameter of that name is ignored.
"input.scs" 16 : statementis not in spectre format.
Warning from spectre during AHDL read-in.
"/home/zxr/circuit_design/MyResearch/delay_1ns/veriloga/veriloga.va", line 28: warning: `(abs)delay()' dose not account for phase shift in small-signal analysis.
My question is about the variable m. I never set the variable m. And I didnot describe it in the delay cell.
Can anyone help me?
rfidea
Europe
Re: [Help] error on simulation about verilogA block
Reply #1 - Mar 8th, 2011, 3:53am
About the m. Check the parameters your other components, the pulse source and resistor it there is any m there. m is used as multiplier for resistors. Check the resistor parameters carefully.
If you do not find the problem, please post your netlist, which is the file input.scs
Reply #2 - Mar 8th, 2011, 5:14am
Patrick,
  Have you looked at the netlist? Is the variable used in the
netlist?
