Jul 26th, 2024, 10:35am
Supply noise filtering in crystal oscillators (Read 2215 times)
Murat H. Eskiyerli
Ex Member
Mar 08th, 2011, 7:04am
Hi All,
I am designing a crystal oscillator in 28nm CMOS using 1.8V thick-oxide devices. It is a simple Pierce oscillator type design. The circuit is mostly done, but I need to meet the specs with certain supply noise injection, i.e. 200mVpp at 100Hz, 10kHz, and 1MHz. Are there any pointers or ideas about how to go about designing a supply filter for such a circuit? Any help would be greatly appreciated.
Murat Eskiyerli
  IP Logged
Re: Supply noise filtering in crystal oscillators
Reply #1 - Mar 14th, 2011, 1:58pm
Determine your transfer function from the power supply to the output.
I suspect you will find that the dominant component of the transfer function comes from the power supply to the output amplifier.
The crystal has such a high Q that little or no OOB will pass thru it directly.
With that you can determine your PSRR needs.
Murat H. Eskiyerli
Ex Member
Reply #2 - Mar 18th, 2011, 5:56am
Thanks for your help.
Murat
  IP Logged
