Jul 17th, 2024, 12:24am
Accessing the model library file section using Skill or Ocean (Read 119 times)
Merrick
Mar 23rd, 2011, 1:49pm
We have a custom corner generation tool for Cadence ADE that creates netlists for various combinations of design variables, temperatures, etc.  and launches the simulation on an SGE queue using ocean.  The device corner is manipulated through the section of the model library file.
Using this tool, I can run corners quickly and then run an ocean script to post process the results.  I always like to verify the design variables and temperature using VAR() to ensure that there wasn't a typo on the inputs to the corner generation tool.  The one thing that I'm unable to verify, however, is the device corner.  Is there a direct way through Skill or Ocean to find the section of the model library file that was used ?
Merrick
bernd
Munich/Germany
Re: Accessing the model library file section using Skill or Ocean
Reply #1 - Apr 26th, 2011, 6:37am
o_currentSession = asiGetCurrentSession( )
asiGetEnvOptionVal( o_currentSession  'modelFiles )
Returns the model file plus section, then it should be easy to get the section only.
* bernd
Just another lonesome cad guy
