Jul 16th, 2024, 8:29pm
Flexible pin naming convention for cells in Cadence Schematic Composer (Read 3207 times)
nara
Apr 20th, 2011, 5:02pm
Dear group members,
This is my first post.
I would like to know the most compact and flexible way of expressing pin and bus naming convention, for a scenario as described:
A block(cell) takes in 32 inputs of 16 bit bus width (and produces output, say similar as input).
It will be highly laborious task to give names of the pins as in1<15:0>, in2<15:0>, in3<15:0>,....in32<15:0> and so on..
And instead of 32 input pins is there a way to have just a single pin of 32*16 bit wide.
Any help in this regard is laudable.
