Jul 2nd, 2025, 12:34pm
Contribution statement (Read 4700 times)
elecky mess
Mar 24th, 2011, 10:43am
Hello, I'm a newbie to Verilog-AMS, and what I am currently trying to do is to assign some value for a voltage at a port or across a branch in some given condition. For example, my Verilog-A code would be like
parameter real c = 1.2;
analog begin
@( condition 1 )
V(a,b) <+ c;
if ( condition 2 )
V(a,b) <+ 0;
I actually made something similar to this, and tried to simulate it in Cadence Hierarchy Editor. It uses NC Verilog simulator, right? But whenever I tried simulation, I got errors and they all pointed the lines where "<+" operators were used. The error messages were like
" ../veriloga.va line xx: Encountered a contribution statement embedded in an analog event.
Remove the contribution statement from the analog event."
Here I got confused. As far as I know, a contribution statement can actually be used only in an analog event, and it is used to assign an expression to a voltage or a current at a port or branch. I think any real number or any parameter as used in my code is a legitimate expression. If I am right, what's wrong with my code?
Re: Contribution statement
Reply #1 - Mar 25th, 2011, 5:08am
[quote author=eleckymess link=1300988590/0#0
@( condition 1 )
V(a,b) <+ c;
[/quote]
The "@" is what makes this an analog event.
NC Verilog is a digital Verilog simulator; you are using AMS, so I think you probably have Spectre running this module.
You may be thinking digitally.  The analog block of an AMS module is evaluated at every timepoint of the transient analysis.  On some of those timepoints, the @(analog_event) will fire, and the simulator would try to make the contribution, but on other timepoints, what do you want to happen?
You probably want something like
@(initial_step)
  vout = 0;
@( condition1)
  vout = c;
V(a,b) <+ transition(vout);
where now, the contribution is not conditional: it always establishes a voltage-source branch between a and b, but the voltage it enforces varies.
