Oct 4th, 2026, 8:29am
4-bit adder using pmos and nmos (Read 2425 times)
Claudiu
Bucharest
Mar 27th, 2011, 10:41pm
I have to implement a 4-bit adder using only nmos and pmos...I am combining 3 NANDs and 3 invertors for this, but I am not allowed to put them in different modules. Here's the code I wrote:
module andmod4(in1, in2, in3, in4, out);
	input in1;
	input in2;
	input in3;
	input in4;
	output out;
	supply1 vdd;
	supply0 gnd;
	//nand(in1, in2, w1);
	pmos(w1, vdd, in1);
	pmos(w1, vdd, in2);
	nmos(w1, i1, in1);
	nmos(i1, gnd, in2);
	//inv(w1, w2);
	pmos(w2,vdd,w1);
	nmos(w2,vss,w1);
	//nand(w2, in3, w3);
	pmos(w3, vdd, w2);
	pmos(w3, vdd, in3);
	nmos(w3, i2, w2);
	nmos(i2, gnd, in3);
	//inv(w3, w4);
	pmos(w4,vdd,w3);
	nmos(w4,vss,w3);
	//nand(w4, in4, w5);
	pmos(w5, vdd, w4);
	pmos(w5, vdd, in4);
	nmos(w5, i3, w4);
	nmos(i3, gnd, in4);
	//inv(w5, out);
	pmos(out,vdd,w5);
	nmos(out,vss,w5);
, but when I test it I get nothing but x and z at the output (except for the case when all inputs are 1 -> I get 1 at output).
Any ideas why this doesn't work?
Claudiu
Edit: the module works for only 2 bits, so I don't think NAND or the inversor is the problem, but the wiring between them (or some other aspect of Verilog that I'm not aware of)
Claudiu
Bucharest
Re: 4-bit adder using pmos and nmos
Reply #1 - Mar 28th, 2011, 12:13am
Sorry, my mistake, because of a copy-paste error (I put vss in some places where gnd should have been)
