Aug 16th, 2024, 3:18pm
best RF PA Floorplan location (Read 1598 times)
makelo
Hillsboro, OR
Mar 30th, 2011, 9:57am
I would like to hear peoples thoughts about the best location for an RF power amplifier in an SoC.
I am floorplanning an RF transceiver with a power amplifier that sinks ~350mWatt of quiescent power.  I can place the PA either in the corner of the die or in the middle along one edge.  Which is best?
In both locations there is plenty of room for multiple ground and Vdd bondwires.  The CMOS SoC is somewhat large and contains considerable digital real estate.  My main concern is about die stress, reliability and getting the heat out.  Is one location better than the other for these issues?
Makelo
Re: best RF PA Floorplan location
Reply #1 - Mar 30th, 2011, 7:06pm
model in your bonding and package impedances - all power and ground pins- with that you are going to see the PA do some pretty crazy things to the power-ground-substrate
Go from there.
