Jul 24th, 2024, 5:59pm
Schottky diode based Sense Circuit... (Read 2596 times)
george
Apr 07th, 2011, 5:02pm
I am new to circuit design dealing with high-speed signals and I need help finding a solution to what is a simple problem for most of you.
I need a high-Z voltage sense circuit for a high-speed I/O line. I have heard this can be done with a Schottky diode but I am not sure how. The point of the circuit is to probe a signal without disrupting it.
Any ideas or directions?
-George
Rakesh
Re: Schottky diode based Sense Circuit...
Reply #1 - Apr 7th, 2011, 7:29pm
What is the signal u r looking at like wat is the magnitude range etc
george
Reply #2 - Apr 8th, 2011, 9:33am
It is for a pass-through/break-out board for Display Port. The peak to peak of the signal shouldn't be more than 1V. However, I would like to spec it at 2V for extra resilience. The signal is differential if you aren't aware of this. It is like USB.
Reply #3 - Apr 8th, 2011, 1:54pm
PCB or IC level design?
Digital sense output or buffered analog signal out?
Maximum frequency?
Accuracy of sensor (offsets?)
To be helpful, need a lot more info to define the problem.
Jerry
