Verilog-AMS
Analysis
Modeling
Design
Theory
Welcome, Guest. Please
Login
or
Register.
Please follow the Forum
guidelines
Aug 28
th
, 2024, 11:19am
Home
Help
Search
Login
Register
PM to admin
Design
Analog Design
› how to determine loop bandwidth for PI with digital filter?
Previous topic
Next topic
how to determine loop bandwidth for PI with digital filter? (Read 7165 times)
supermoment
Apr 12
th
, 2011, 8:15am
IP Logged
raja.cedt
Re: how to determine loop bandwidth for PI with digital filter?
Reply #1 -
Apr 12
th
, 2011, 9:01am
what do you mean by PI loop BW..its an open loop system
IP Logged
supermoment
Reply #2 -
Apr 12
th
, 2011, 5:12pm
PI output go to a CDR loop
IP Logged
raja.cedt
Reply #3 -
Apr 12
th
, 2011, 9:35pm
yes,
so should ask CDR bandwidth riteee....
so this is a different question now. Tell me weather your CDR is 1st order or 2nd order from there we can decide.
IP Logged
supermoment
Reply #4 -
Apr 13
th
, 2011, 1:12am
since PI replacing the vco, there is no 1/s integral part. Then it should be 1st order.
digital loop filter is used.
IP Logged
raja.cedt
Reply #5 -
Apr 13
th
, 2011, 5:02am
correct but what about loop filter. General rule is if you need only phase tracking use first order, but if any frequency tracking required (like systems which are having ppm between TX and RX) then 2nd order imp.
Thanks.
IP Logged
supermoment
Reply #6 -
Apr 13
th
, 2011, 5:55am
how to determine the loop filter?
input does not have ssc.
could you point me some of the good papers?
IP Logged
raja.cedt
Reply #7 -
Apr 14
th
, 2011, 10:12pm
hi,
http://www.ece.tamu.edu/~spalermo/ecen689/cdr_hlee_stanford_2006.pdf
http://www.ece.tamu.edu/~spalermo/ecen689/dig_cdr_bb_pll_sonntag_jssc_2006.pdf
Thanks.
IP Logged
supermoment
Reply #8 -
Apr 14
th
, 2011, 11:25pm
thank you
IP Logged
supermoment
Reply #9 -
Apr 24
th
, 2011, 7:28am
how could the PI has 2nd order loop??
2nd order loop implies that the PI can adjust its clock frequency. The PI has only fixed frequency but the phase can be adjusted.
IP Logged
raja.cedt
Reply #10 -
Apr 24
th
, 2011, 12:36pm
good question, i also understand little bit. So please refer the above thesis. What i feel is rate of change of phase is frequency. If you know any answer for this let me know
Thanks.
IP Logged
supermoment
Reply #11 -
May 12
th
, 2011, 6:09am
got it.
freq=d(phi)/dt (1st order)
ramping freq = d(phi)^2/dt^2 (2nd order)
IP Logged
Previous topic
Next topic
Forum Jump »
» 10 most recent Posts
» 10 most recent Topics
Design
- RF Design
»» Analog Design
- Mixed-Signal Design
- High-Speed I/O Design
- High-Power Design
- Mixed-Technology Design
Analog Verification
Measurements
- RF Measurements
- Other Measurements
Modeling
- Semiconductor Devices
- Passive Devices
- Behavioral Models
Design Languages
- Verilog-AMS
- VHDL-AMS
Simulators
- Circuit Simulators
- RF Simulators
- AMS Simulators
- Timing Simulators
- System Simulators
- Logic Simulators
Other CAD Tools
- Entry Tools
- Unmet Needs in Analog CAD
General
- Tech Talk
- News
- Comments and Suggestions
- Opportunities
« Home
‹ Board
» Powered by
YaBB 2.2.2
YaBB
Copyright 2002-2024
Designer’s Guide
All rights reserved.
Send comments or questions to
editor@designers-guide.org
. Consider
submitting
a paper or model.
