Jul 17th, 2024, 11:31am
Long term jitter (Read 3694 times)
raja.cedt
Long term jitter
Apr 12th, 2011, 8:59am
hi,
what is the meaning of long term jitter @ 200Meg,because i have seen this specification in some PLL spec table.
Thanks.
nrk1
Re: Long term jitter
Reply #1 - Apr 25th, 2011, 11:30pm
Probably means the long term jitter when the PLL output frequency is at 200MHz(just a guess).
PLLs output jitter variance increases with time upto ~ 1/bandwidth and then flattens out assuming a jitter free reference. This could refer to the flattened out variance.
raja.cedt
Reply #2 - Apr 26th, 2011, 11:57am
hi,
could you please explain clearly.....
Thanks.
nrk1
Reply #3 - Apr 27th, 2011, 8:00pm
The period jitter of an oscillator is (the variance of) how much each each period varies from the average period T0. Similarly, you can define the variance of how much the duration of N periods of the oscillator differs from N*T0. The variance of this will be higher. (For an open loop VCO with white noise sources, it'll be N times higher). For a PLL, the variance increases as N increases and flattens out after N*T0 exceeds the bandwidth of the PLL. I assume your spec is for some large N in this range.
Nagendra
