boe is correct; if iprobes are implemented as 0V voltage sources, then that would add a row for the branch current and an extra node, which gets you quite close to the number of equations.
BSIM4 can also add several internal nodes per device (up to 7: internal drain, internal source, two internal gate nodes, and four internal body nodes).
