dxt78
Ohio
I'm getting a strange error when using two Verilog-A blocks (pic attached) together. I test each block on their own and they work fine. When I try to use them together though, I get this error:
"ERROR (CMI-2116): I3: Too few terminals given (3 < 4)"
The first block ("min_block") takes three voltages and finds the minimum.
The second block ("subtract_block") takes two voltages and outputs the difference.
My Verilog-A for the min_block is:
"`include "constants.vams" `include "disciplines.vams"
module min_block(x, y, z, out); electrical x, y, z, out;
analog begin : themodule real vx,vy,vz; real temp, temp2; vx = V(x); vy = V(y); vz = V(z);
temp = min(vx,vy); temp2 = min(temp,vz); V(out) <+ temp2; end endmodule"
And my code for the subtract_block is:
module min_block(x, y, difference); electrical x, y, difference;
analog begin : themodule real vx,vy; real temp; vx = V(x); vy = V(y);
temp = (vx - vy); V(difference) <+ temp; end endmodule
