Jul 18th, 2024, 2:29am
Command o create Netlist in Spectre (Read 6252 times)
analog_design
INDIA
May 03rd, 2011, 12:45am
I want to run simulation through command prompt in spectre. Please, let me know what is command to create netlist from schematic circuit. I forgot it and try to look in to user manual but, I didnt find it. Please, explain me how i can run simulation without use of ADE ?
You help would be appreciated.
Warm Regards
View Profile analog_design   IP Logged
Re: Command o create Netlist in Spectre
Reply #1 - May 3rd, 2011, 4:50am
Analog_design,
 You will need to use ADE to create the netlist, or create it manually.
To create a netlist in ADE, select
      Simulation --> Netlist --> Create or Recreate.
Once you have the netlist you can simulate with Spectre from the
command line so you can simulate without ADE.
boe
Reply #2 - May 6th, 2011, 11:40am
Analog_design,
you can also use ADE to create OCEAN script for netlisting.
B O E
analog_design
INDIA
Reply #3 - May 8th, 2011, 9:54pm
Thank you very much for your reply. I would like to simulate without use of ADE. i know the command to simulate i.e spectre xxx.scs  but, I do not know the procedure to create netlist of circuit.
Please, let me know the steps irrespective of use of ADE.
your reply would be appreciated.
Thank you.
Warm Regards
Reply #4 - May 9th, 2011, 3:59am
Analog-design,
  You can simulate without the environment as described, using the
spectre command. However, netlisting is not simulation, netlisting is
part of the environment. Your options for netlisting are either interactive, ADE, batch mode, OCEAN, or manually creating the netlist.
boe
Reply #5 - May 9th, 2011, 9:50am
analog_design wrote on May 8th, 2011, 9:54pm:
Thank you.
As already stated, you could use an OCEAN script (assuming you have your design as a Cadence schematic). I am too busy to write code that I can have generated, so I always use ADE once to create an OCEAN script template for netlisting, which I modify as needed.
B O E
analog_design
INDIA
Reply #6 - May 12th, 2011, 11:35pm
Hi All,
Thank you very much to all for help and information
Warm Regards
