Sep 19th, 2026, 9:38am
#nodes and #equations in Spectre (Read 2497 times)
leander
Beijing
Apr 13th, 2011, 5:56pm
I am doing a postlayout simulation for a PA. Their are a lot of parasitic Rs and Cs. The simulator reports insufficient memory when doing PSS analysis. I then notice from the inventory that the equations is much more than the nodes (>30X). Why this is the case? I thought the number of equations should equal the number of nodes plus independent sources and inductors.
Circuit inventory:
             nodes 9929
         equations 347049
            iprobe 166629
    ahdl simulator 1
             bsim4 1400
         bsource_1 313
         capacitor 75946
             diode 960
          inductor 334
           isource 2
              port 2
          resistor 83473
           vsource 2
boe
Re: #nodes and #equations in Spectre
Reply #1 - Apr 14th, 2011, 2:58am
leander,
You have ~166 000 iprobes. I expect that the simulator solves those too. Also, you may have equations for derivatives of signals.
B O E
Reply #2 - Apr 14th, 2011, 7:22am
boe is correct; if iprobes are implemented as 0V voltage sources, then that would add a row for the branch current and an extra node, which gets you quite close to the number of equations.
BSIM4 can also add several internal nodes per device (up to 7: internal drain, internal source, two internal gate nodes, and four internal body nodes).
boe
Reply #3 - Apr 18th, 2011, 9:43am
Geoffrey,
additional question: I'd expect the #nodes in the inventory to include the internal nodes of any (BSIM or other) models. Is that correct?
B O E
Reply #4 - Apr 25th, 2011, 5:01am
BOE -
I think #nodes generally does not include internal nodes of models.
John O Donovan
San Jose, CA
Reply #5 - Apr 25th, 2011, 9:46am
Geoffrey is correct. Nodes are circuit nodes, not including any internal nodes of devices.
 John
boe
Reply #6 - May 6th, 2011, 10:32am
Geoffrey and John,
Thanks!
B O E
