Jul 17th, 2024, 12:28pm
verilog-AMS update issue (Read 1761 times)
eecs4ever
Apr 14th, 2011, 11:33pm
I've found that when I run AMS simulations, it does not updated properly.
For example. In my verilog file,  i have a parameter which defines the period of a clock signal to be 100ns. If i change this parameter to 50 ns and save the verilog file. And then netlist & run. The simulation still generates a clock signal at 100 nS even though i've updated this parameter to other values!
.parameter clockperiod = 100n // 50n , 25n , 200n
However, if i hardcode the number into the clock generating expression.
For example
always #(25n) clk = ~clk;
then the clock period will update to reflect the 50ns period.
Does any one know why AMS does not update the parameter properly?
Thanks Smiley
Marq Kole
Hmmm. That's
weird...
Eindhoven, The Netherlands
Re: verilog-AMS update issue
Reply #1 - Apr 15th, 2011, 12:58am
You will need to provide more information:
- what AMS tools do you use, i.e. Cadence tools, Synopsys tools, etc.
- how do you control your simulation, i.e. from a script or through a GUI?
- what is the relation between the parameter in your verilog-file (which I presume has a format parameter integer clockperiod = 50) and the .parameter line you showed?
Cheers,
Marq
