Jul 17th, 2024, 12:49pm
How could I make the Bits as a variable or param in verilogA? (Read 1671 times)
newic
Apr 23rd, 2011, 5:21am
How could I make the Bits as a variable or param?
`include "constants.vams"
`include "disciplines.vams"
`define Bits 8
module adc (out, in, clk);
Re: How could I make the Bits as a variable or param in verilogA?
Reply #1 - Apr 25th, 2011, 5:59am
In principle, you could use a parameter (but NOT a variable); see this example:
http://www.designers-guide.org/VerilogAMS/functional-blocks/data-converter/conve...
   parameter integer bits = 8 from [1:24];      // resolution (bits)
   input in, clk;
   output [bits-1:0] out;
However, I'm not aware of any simulator that supports this; they all need the number of terminals of the adc to be known before parameter processing.
