Sep 10th, 2024, 1:59pm
Dac Non Linearity Affecting The baseband noise in SD Mod (Read 2416 times)
jefkat
Apr 21st, 2011, 6:25am
Hi Guys,
         I was simulating a multi-bit sig del Modulator. I notice that when I introduce the non linearity in the DAC (by delibrately adding mismatch in the DAC caps)then besides the appearance of  harmonic dist the noise floor of the output of the Modulator, in the baseband, goes up significantly.
What could cause this?.  I did the sim in matlab first and then in cadence/spectre. The result is the same in both .
        Any interesting ideas?
        Thanks for your time.
nrk1
Re: Dac Non Linearity Affecting The baseband noise in SD Mod
Reply #1 - Apr 30th, 2011, 10:18am
Out of band noise components (which are at a rather high level in a delta sigma modulator) fold into the signal band due to nonlinearity in the DAC and add to the in band noise.
Nagendra
