Aug 28th, 2024, 3:17am
offset cancellation (Read 1884 times)
Rakesh
offset cancellation
Apr 24th, 2011, 2:50am
    I have a clocked comparator with positive feedback. I need to cancel offset in that comparator . My offset should be less than 0.3mV. Please suggest me some way.
Since my comparator is highly non linear, how to do auto zeroing as feedback operatiionis linear
nrk1
Re: offset cancellation
Reply #1 - Apr 25th, 2011, 10:47pm
Use a preamp with enough gain to attenuate the comparator offset sufficiently.
Comparator offset sigma ~ sqrt(sigma_VT^2 of all transistors "participating" in amplifying the input)
(very crude estimate)
Use offset cancellation in the linear preamp.
Take care of dynamic offset by layout symmetry, less common mode voltage swing etc.
Rakesh
Reply #2 - Apr 27th, 2011, 5:53pm
Agreed with you. But the problem with having preamp is the power consumption. So only was wondering is it possible to have some offset cancellation technique in comparator only
Reply #3 - Apr 29th, 2011, 6:06pm
open a book on the subject - the architecture needed here is in many many books.
page 473 Razavi (chapter 13 on mismatch, Design of Analog CMOS) or the cover of the Johns-Martin textbook shows the architecture.
Rakesh
Reply #4 - Apr 30th, 2011, 3:11pm
Thanks Jerry,
                  The references deal with canceling offset for a comparator which has a constant gain or the system isLTI system.
If u have a comparator with positive feedback and transistors operating in every region we cannot use negative feedback to detect the offset.
So the question is how to go about solving offset in these comparators.
One such example of a comparator is clocked sense amplifier used in SRAM.
Rakesh
raja.cedt
Reply #5 - May 1st, 2011, 10:16am
hi,
you can use open loop calibration just by injecting some current to make unbalanced legs to balance.
Thanks.
Rakesh
Reply #6 - May 1st, 2011, 1:08pm
  True, If i need the offset to be less than 500uV, designing the switching of current sources and the open loop calibration with low power is rather difficult
Rakesh
Reply #7 - May 2nd, 2011, 5:01am
Rakesh,
  Look on pages 21~23 of this presentation
http://www.ssc.pe.titech.ac.jp/publications/2008/matsu/Digital%20assist_081025.p...
for and approach for offset cancellation. They reference a paper
in the Journal of Solid-State Circuits so you can probably find more
details.
solidstate
Munich, Germany
Reply #8 - May 2nd, 2011, 5:38am
Maybe you can apply a known ramp to the comparator and measure the time it takes for the comparator to toggle? Or two ramps, if the offset is decision-dependent.
Probably not fast enough to do for every sample, but maybe useful to tune a feedforward compensation?
Rakesh
Reply #9 - May 2nd, 2011, 8:20am
Thanks sheldon,
                     The ppt are really good.
Rakesh
Reply #10 - May 2nd, 2011, 1:07pm
sounds like you want a static system. That said, the prior suggestions of injecting offset are possibilities.
I have also seen changing the geometry (switching pieces in and out) of the loads above the differential pairs, and other size changes (using switches again) of various pieces.
You got to run an alignment circuit every once in a while.
