Jul 19th, 2024, 2:15pm
EDIF In Error (Read 3993 times)
EDIF In Error
May 03rd, 2011, 11:01pm
Hi Guys,
I jumped into a problem when I tried to import an EDIF 200 file for Virtuoso symbol view. The log file edifin.log is shown below.
Quote:
error at line :1 between '' and ''
       Unexpected character "/" in input
error on line 1: between '' and ''
       syntax error
Translation complete.
There were 0 warning messages and 2 errors in the design
The following is the head of the imported EDIF file.
Quote:
/* Edif file name is "CADENCE_EDIF" */
/* EDIF version: 2 0 0 */
library("library_name") {
 SCALE = 1.0 / 10.0;
 ROUTE_GRID = 1024;
 set_route_grid(ROUTE_GRID);
 set_meter_scale(0.0254 / (160 * SCALE * ROUTE_GRID));
 symbol ("AD1HSV1") {
   set_minimum_boundary (0 * SCALE, 0 * SCALE, 140 * SCALE, 140 * SCALE);
Software version is Virtuoso IC6.1.5.500.1.
Can you help me figure it out? Thank you.
Yawei
ljlu
shanghai, PRC
Re: EDIF In Error
Reply #1 - Mar 6th, 2012, 12:33am
I encountered the same question. If you've solved it, tell me. Thanks!
