Jul 17th, 2024, 4:18pm
Verilog-AMS always @(above issue (Read 11429 times)
Sumit Adhikari
May 05th, 2011, 9:00am
Hello All,
I have a piece of code like as follows :
  real   osc_out_val ;
  real   osc_out_r   ;
  analog
  begin//{
     osc_out_val = V(osc_out);
     if(osc_out_val >= 0.6) osc_out_r = 1.0 ;
     else                   osc_out_r = 0.0 ;
  end//}
  logic out ;
  reg   out ;
  always @(above(osc_out_val - 0.6)) out = 1'b1 ;
  always @(above(0.6 - osc_out_val)) out = 1'b0 ;
The problem is "osc_out_r" is correctly changing but "out" seldom changes and is glitchy.
What could be the issue ?
By the way I do not have a converging dc solution and the message from ultrasim is as follows :
**** NUM_EVENTS: 159894  ****
   WARNING (USIM-6501): The DC solution did not converge at ''dc_maxevent''.
       The UltraSim simulator will approximate the DC solution. Try using a
       different dc option to improve DC accuracy.
   WARNING (USIM-6502): The DC simulation ended prematurely and the results
       may be incorrect. Try using a different dc option to improve DC
       accuracy before running the simulation again.
DC: user time: 0:10:20 (620.350 sec), system time: 0:00:04 (4.560 sec), real time: 0:10:26 (626.300 sec)
DC: memory:                           83.8369 MB   total:      107.0373 MB
Sumit
Sumit
Re: Verilog-AMS always @(above issue
Reply #1 - May 6th, 2011, 7:45am
I thought @above was an analog event -- ie, it should go in the analog block.  It is supposed to control the analog timestep to accurately resolve the crossing, but you've got it in a digital always block.
Sumit Adhikari
Reply #2 - May 6th, 2011, 8:40am
Yes, but in that case "out" cannot be a logic type!
boe
Reply #3 - May 6th, 2011, 11:30am
Sumit Adhikari,
try using an integer in the analog block; then use a digital always block to test the integer and convert it to logic.
B O E
Sumit Adhikari
Reply #4 - May 9th, 2011, 1:22am
I tried it earlier. but the integer has been declared in the analog block and affirma does not compile the digital check over the integer. Following is the code for your reference :
  real    osc_out_val ;
  real    osc_out_r   ;
  logic   out         ;
  reg     out         ;
  integer flag        ;
  analog
  begin//{
     //@(cross (osc_out_r - 0.5, 1)) $write("%2.20f,%f\n",$abstime,osc_out_r);
     //@(cross (osc_out_r - 0.5,-1)) $write("%2.20f,%f\n",$abstime,osc_out_r);
     @(cross (osc_out_r - 0.5, 1)) flag = 0;
     @(cross (osc_out_r - 0.5,-1)) flag = 1;
  end//}
  //always @(above(osc_out_val - 0.6)) out = 1'b1 ;
  //always @(above(0.6 - osc_out_val)) out = 1'b0 ;
  //always @(cross (osc_out_r - 0.5, 1)) out = 1'b1 ;
  //always @(cross (osc_out_r - 0.5,-1)) out = 1'b0 ;
  always @(flag)
     if(flag == 0) out = 1'b1 ;
     else          out = 1'b0 ;
kind of tragedy for me now! Sad
Sumit
boe
Reply #5 - May 9th, 2011, 9:16am
Sumit Adhikari,
input in, clk;
output out;
wire in;
reg out;
electrical clk;
always @(cross(V(clk) - 2.5, 1)) // Code to detect the analog event.
    out = in;
should work (example code from Cadence). Alternatively (also after a Cadence example), for your example Code:
always begin
  #5 out = !flag
in the digital part of your module should work as well.
NB: The delay was part of the example. It should also work without.
B O E
boe
Reply #6 - May 9th, 2011, 9:29am
Sumit Adhikari,
Sumit Adhikari wrote on May 9th, 2011, 1:22am:
IMO, the problem with your code is that osc_out_r is discontinuous and therefore does not have any zero crossings. You should try cross directly on V(osc_out) [or on  osc_out_val].
B O E
Edited:
I recommend: Code:
always @(cross (V(osc_out)-0.5, 1)) out = 1'b1 ;
always @(cross (V(osc_out)-0.5,-1)) out = 1'b0 ;
in the discrete context or similar with above. Should work.
boe
Reply #7 - May 9th, 2011, 9:39am
Geoffrey,
Geoffrey_Coram wrote on May 6th, 2011, 7:45am:
You can use @cross/@above in the digital part (discrete context) of V-AMS models to detect continuous events in the digital domain.
B O E
Sumit Adhikari
Reply #8 - May 13th, 2011, 1:41pm
Thanks, but this always@ stuff is not working with cadence. And this is problem is with cadence only. I checked this works with other simulator.
My old code is fine with other simulator and is a problem with cadence.
Thanks for the support.
Sumit
boe
Reply #9 - May 17th, 2011, 9:08am
Sumit Adhikari,
The connect module (from Cadence) that converts analog signals into digital ones uses (excerpt):
reg Xin; real Kin;
analog Kin = ...;
always @(above(Kin-vthi,ttol,vtol)) Xin=0;
always @(posedge(Xin)) ...
I can assure you, it works.
Which version do you use? And which analog solver?
B O E
