Jul 17th, 2024, 2:42pm
Help me understand this verilog-A code (Read 3996 times)
afridi
May 17th, 2011, 4:34am
Help me understand this verilog-A code .I simply dont know anything about verilog-A. I want to modify this code for low voltage of 0 and high voltage of 2.5V.Can anyone help me modify this.
   This is a code for a comparator
   module comparator(sigin, sigref, sigout);
   input sigin, sigref;
   output sigout;
   electrical sigin, sigref, sigout;
   parameter real sigout_high = 10;
   parameter real sigout_low = -10;
   parameter real sigin_offset = 0;
   parameter real comp_slope =1000;
   analog begin
   @ ( initial_step ) begin
   if (sigout_high <= sigout_low) begin
   $display("Range specification error. sigout_high = (%E) less than sigout_low = (%E).\n", sigout_high, sigout_low );
   $finish;
   V(sigout) <+ 0.5 * (sigout_high - sigout_low)
   * tanh(comp_slope*(V(sigin, sigref)- sigin_offset))
   + (sigout_high + sigout_low)/2;
REGARDS
The more things you do, the more you can do.(Lucille Ball)
boe
Re: Help me understand this verilog-A code
Reply #1 - May 17th, 2011, 8:46am
Dfury,
Set sigout_high and sigout_low accordingly.
Note that tanh has an output range of +/-1.
B O E
afridi
Reply #2 - May 17th, 2011, 8:52am
okay.what about how we control the comparators speed? i mean if one input is changing at a rate of 1000MHz then will this work?
Reply #3 - May 17th, 2011, 12:57pm
Did you look at the comparator posted on this site?
http://www.designers-guide.org/Books/dg-vams/ch5/ch5-listing05.tgz
It has td and tt (delay and transition time), which you should be able to use to control the speed.
afridi
Reply #4 - May 17th, 2011, 1:24pm
okay but is this an analog input comparator?
boe
Reply #5 - May 18th, 2011, 2:30am
Dfury,
The code you suggested in the initial post is infinitely fast. It just scales the input and limits with tanh.
The code Geoffrey suggested is also a continuous-time comparator. However, you need to scale the output appropriately.
B O E
