Jul 17th, 2024, 2:40pm
frequency-dependent parameter in verilog a (Read 6655 times)
Kem
May 10th, 2011, 8:36am
I'm new here and have no experience with verilog a before. I 'm working on a FET transistor model and i have to do it with verilog a. I would like to describe a noise parameter as a function of frequency.
<i_d^2>=4*R*K*T0*B*(w*Cgs)^2 / gm
I would like to know how I can implement a frequency-dependent parameter since verilog a only works in the time domain ?
thanks a lot for your help
kem
rfidea
Europe
Re: frequency-dependent parameter in verilog a
Reply #1 - May 10th, 2011, 8:57am
There is a function, flicker_noise(pwr, exp [ , name ]), that you can use for this. There is no limitation for the variable exp so you can use the function for increasing noise with frequency, if you like.
By the way, veriloga works both in frequency and time domain.
Kem
Reply #2 - May 10th, 2011, 9:03am
thanks a lot for your answer!
In my case i will do it with white_noise function. Does it means i just have to create a frequency paramerter ?
kem
rfidea
Europe
Reply #3 - May 10th, 2011, 9:37am
I do not understand why you should use white_noise if you would like to have a frequency dependent noise source when there is a function for that?
If you need a flat noise response for frequencies above some corner frequency and a 1/f relationship below that corner frequency you can add a white noise source and a flicker noise source by white_noise(..) + flicker_noise(..)
Kem
Reply #4 - May 10th, 2011, 12:20pm
thanks for your answer. I think i have to use both of them.  I have to model the transistor untill ~30 GHz. And the really interessant frequency domain is f>2 GHz
Kem
Reply #5 - May 16th, 2011, 9:19am
i still haven't solved my problem. The real question is how to model the induced gate noise current of a fet transistor. Are there someone who can help me ?
thanks
kem
Reply #6 - May 17th, 2011, 12:51pm
Did you look at how correlated noise is done in the MOS11 model, posted on this site?
http://www.designers-guide.org/VerilogAMS/semiconductors/mos11010/mos11010.va
Kem
Reply #7 - May 18th, 2011, 5:52am
Thanks for pointing out the link. I have read it but i couldn't really understand it since there are comment missing.
kem
