Aug 28th, 2024, 3:19pm
Native vs Standard Vt or Low Vt NMOS (Read 16178 times)
hacksgen
Ex Member
May 11th, 2011, 4:48am
Hi everyone,
As I understand the native devices have lowest threshold close to zero, better matching and also low noise like flicker due to low doping.
Why is it that then not many designs use them for design of analog circuits like opamps in advanced tech. such as 65nm or 90nm where we have low voltage headroom?.
I have searched online and read through many documents but none of them clarify why native is not preferred over standard or low Vt? Can anyone explain this perhaps in relation to an opamp as an example.
Many Thanks
  IP Logged
Lex
Eindhoven, Holland
Re: Native vs Standard Vt or Low Vt NMOS
Reply #1 - May 11th, 2011, 5:37am
Come on.. did u really think about it? Let me give u some questions. And see if u can answer them..
- Do native transistors come for free? Or do u need an extra mask?
- How is the matching and modelling of native transistors?
- How usefull is a native transistor? For example in your opamp, can u easily build a current mirror with native transistors?
hacksgen
Ex Member
Reply #2 - May 11th, 2011, 6:56am
Hi Alexander,
Like I said, my understanding comes from what I read in other forums and few papers found on IEEE. So it might be that I am wrong which is why I post my question here.
Usually there is no need of  additional mask in creating native transistors since it is formed directly on the substrate. (I quote this from a IEEE paper that I found). Even if an additional step is needed this should only increase the fabrication costs which I am not concerned with here. I am more interested in its use for building analog blocks assuming costs are not a factor.
Matching relates to how the transistors are uniform in there properties and I think the uniform doping of the substrate allows only small variations between transistor parameters like in case of a curent mirror.
I dont understand what you mean by modelling. Do you mean the model parameters provided by the foundry?
From the lecture material provided in the website of Prof. Philip E. Allen it is given that native transistors allow increased ICMR in an opamp when characterized. Did you mean this that the transistors are not characterized properly?
The usefulness of the native transistor is something I am not sure about since I have not found many papers using it.
This is why I put of the question here so experienced forumites might answer.
As I have never used it or created layouts from it so haven't got a clue as to whether creating layouts is hard or easy.
  IP Logged
boe
Reply #3 - May 12th, 2011, 12:54am
Let me give you a few pointers.
hacksgen wrote on May 11th, 2011, 4:48am:
... As I understand the native devices have lowest threshold close to zero, better matching and also low noise like flicker due to low doping.
Is that what your foundry's data says?
hacksgen wrote on May 11th, 2011, 6:56am:
...Usually there is no need of  additional mask in creating native transistors since it is formed directly on the substrate. (I quote this from a IEEE paper that I found).
Once upon the time... Nowadays they get their own implantation to set the threshold voltage to the desired value near zero.
Quote:
Why is it that then not many designs use them for design of analog circuits like opamps...
Usually, they are only used if they are really needed because for most designers (and their bosses) costs are the factor. And what kind of circuits are built in 65/90 nm? Purely analog or mixed-signal circuits with a lot of digital content?
That's not Alexandar's point. Think about the operating point of the transistors in the current mirror. And don't forget the Vth,native implantation.
Which models do you think the foundries focus on? Those that are used in millions on every circuit or those only a few designs ever use? On which devices do they have the most data?
B O E
AnalogDE
Reply #4 - May 12th, 2011, 9:46am
I don't get what's wrong with using 0-vt (native) transistors in a current mirror configuration.  In my process they have a lower mismatch coefficient.  As long as I can bias them with a good enough overdrive what's the issue here?  They should work better since Vth=0 leaves more headroom.
boe
Reply #5 - May 12th, 2011, 10:46am
AnalogDE wrote on May 12th, 2011, 9:46am:
Did you try to simulate it? What is the operating point?
B O E
AnalogDE
Reply #6 - May 12th, 2011, 11:12am
I simulated a comparator across PVT and they seemed to work fine.  They are biased in saturation.
Lex
Eindhoven, Holland
Reply #7 - May 12th, 2011, 11:56pm
PVT? Suppose your minimum Vds=200mV. So your Vgs-Vt must be higher than that. Including process and temperature... your overdrive voltage must be huge to have some reliable operation around the corners...
boe
Reply #8 - May 13th, 2011, 6:22am
Hi AnalogDE,
Did you try minimum Vt corner?
Remember Vds > Vgs - Vt requires Vt > 0 for standard current mirror topology.
B O E
RobG
Bozeman, MT
Reply #9 - May 13th, 2011, 8:28am
Sheese, you guys are being a little harsh, it was a fair question. Personally, I have never been involved with a process that had a "native" device for free even though that some claim that no extra steps are needed (all you need to do is block the implant, and not just once upon a time). This is too bad because they have some neat uses and are used all the time when available. You mostly have to make sure the gate-drain has enough breathing room. That, and they don't always turn off with Vgs=0 (so you can use them for current sources without all the crap generally required).
So to answer your question, it isn't used generally available so that is why people don't use them more. (Matching is better because there are less dopants, Alexandar, and modeling isn't an issue.)
Two uses that I have seen are opamps that can have rail-to-rail inputs (the VT is 0 or negative when the input is at the bottom rail, but body effect increases it enough to function when at the top rail). There was a paper (ISSCC?) a while back with this application. The other use is a "free" cascode (0-Vt on top of a normal Vt).
rg
Reply #10 - May 13th, 2011, 11:15am
Some background:
Threshold on CMOS can be anything you want it to be.
Anything. It is selectable by the implant doping under the gate region. This is very much a foundry controlled thing. (Also affected by the dielectric of the gate oxide and thickness of the oxide)
PMOS/NMOS thresholds are typically set at 25% to 35% of the voltage between Vdd and ground.
Why these threshold levels?
Logic Design - it gives the best logic immunity to false logic states due to ground bounce and power rail dips.
So called "native" transistors, used to also be known as "depletion" transistors, where the Vth could be near zero, or even negative. (You had to hold the gate to a negative voltage on NMOS to keep the thing turned off)
My experience with foundries has shown that the generic transistors that are commonly used in the digital design are the best controlled, most accurately modeled, devices, just due to foundry priority.
Because of the above fact, I try to avoid using the "native" devices. Better matching? Perhaps, but they data collected needs to be questioned.
rfcooltools.com
Reply #11 - May 13th, 2011, 11:57am
Native devices aside from the questionable modeling  usually have a minimum length several times greater than the process node.  For example 40nM process has a min length of 300nM for the zero Vt devices.
I find them to be useful as source followers where dc headroom is limited.
http://rfcooltools.com
