Aug 29th, 2024, 7:18am
loop bandwidth and ppm tolerance? (Read 4571 times)
supermoment
May 12th, 2011, 6:14am
For the 1st order PI CDR, if it can tolerate until 500ppm of freq1.
Does it mean the loop bandwidth is around (500ppm/1e6)*freq1?
Is the loop bandwidth different to the ppm tolerance?
rfidea
Europe
Re: loop bandwidth and ppm tolerance?
Reply #1 - May 12th, 2011, 8:47am
What is a PI CDR?
supermoment
Reply #2 - May 13th, 2011, 5:28pm
PI = phase interpolator
CDR= clock and data recovery circuit
Reply #3 - May 16th, 2011, 5:40pm
if you want an answer here I think you need to define the question a lot more
raja.cedt
Reply #4 - May 19th, 2011, 12:03pm
loop BW: How fast it can track Phase and frequency variations.
PPM(specific to CDR): How much frequency difference that can be tracked by CDR between data and clock with out loosing lock.
For a first order CDR there is no PPM (for most of the cases), i guess you are intended to ask 2nd order CDR
PI based CDR means Phase interpolation based Clock and Data Recovery
Thanks.
newic
Reply #5 - May 20th, 2011, 6:12pm
I think the first order PI based CDR can tolerance some PPM, depending on filter setting.
For the loop BW, it is mainly determined by main loop parameter, excluding the 2nd order loop.
