Jul 17th, 2024, 1:20pm
How to extract s-parameters from datapoints in Spectre ? (Read 2096 times)
Mayank
May 12th, 2011, 11:04pm
Hii,
I gotta query.
I have a table of Datapoints indicating Attenuation in dBs against corresponding frequencies, like
FREQUENCY  ----   ATTENUATION
 (MHz)                       (dB)
0.064 ----------------- 0.08
0.512 ----------------- 0.13
1.000 ----------------- 0.20
48.00 ----------------- 1.35
200.0 ----------------- 3.2
400.0 ----------------- 5.8
How do i model a TLINE in SPECTRE with these parameters so as to extract s-parameters out of it ??
Mayank.
weber8722
Re: How to extract s-parameters from datapoints in Spectre ?
Reply #1 - Nov 17th, 2011, 8:41am
Hi, I would create a little s2p file for my own with f s11 s21 s12 s22 in dB and with phase in degrees. You can directly use your values, but need to add the phase too - simple if you know the length.  :)
Spectre can include this s2p file using analogLib/nport.
