Aug 28th, 2024, 7:20pm
body effect decreases output impedance in source followers? (Read 2057 times)
surreyian
May 18th, 2011, 1:37am
Hello all,
In razavi's design of analog CMOS integrated circuit, chapter 3, it states/shows that body effect decrease the output resistance.
But I find it puzzling. I bias the NMOS source with a certain voltage, eg 0.3V.
Setup 1: Base and Source are connected together to 0.3V bias. (No body effect)
Setup 2. Source is connected to 0.3V whilst base is connect to ground. (with Body effect)
Id=(Vgd-Vth)^2K.
Based on the equation, setup 2 Vth will be greater than setup 1, hence reducing Id, hence increase output resistance. Am I right in the analysis?
If that is the case how does body effect reduces output impedance?
raja.cedt
Re: body effect decreases output impedance in source followers?
Reply #1 - May 19th, 2011, 11:57am
hello..this is small signal o/p impedance and expression is 1/(gm+gmb), so it decrease.  but you are arguing from large signal and that to some mistake is there in that equation.
Thanks.
