Aug 28th, 2024, 11:15pm
PMOS and NMOS output resistance (Read 8983 times)
surreyian
May 18th, 2011, 1:39am
Hello all,
the output resistance is given as
1) satuation region, R=1/(Lamda*Id).
2) linear region, R=1/[u.Cox.(w/l).(vgs-vth)]
In these cases, PMOS will have higher outout resistance as PMOS has lower mobility and Id. Is my understanding correct?
However in Razavi's design of analog CMOS integrated circuit, chapter 2. It states that for given dimensions and bias current, NMOS has higher output resistance. How does this statement come about?
RobG
Bozeman, MT
Re: PMOS and NMOS output resistance
Reply #1 - May 18th, 2011, 8:29am
surreyian wrote on May 18th, 2011, 1:39am:
Hello all,
I've never investigated this issue, but output impedance is only important in the saturated region, and there is no mobility term in your equation for that region. [edit - sorry, mobility is in the Id term, I see what you are saying about how the PMOS should have high Rds]
« Last Edit: May 19th, 2011, 8:21am by RobG »
boe
Reply #2 - May 19th, 2011, 8:02am
RobG wrote on May 18th, 2011, 8:29am:
Hello all,
Surreyian,
Note that for equal Id, the small signal resistance rds = 1/(Lambda*Id) depends on the constant, which is different for nMOS and pMOS.
Also note that you need more overdrive for the pMOS to achieve the same current assuming equal-sized MOS transistors - in this equation the mobility is hidden in the current.
B O E
dxt78
Ohio
Reply #3 - May 19th, 2011, 8:09am
Razavi's statement does seems confusing, and there was some previous discussion on this here:
http://www.designers-guide.org/Forum/YaBB.pl?num=1115223850
raja.cedt
Reply #4 - May 19th, 2011, 11:33am
hi,
current depends on number of electrons passing through area per sec. So mobility indicates speed of the electrons but number of electrons also matter ..
Thanks.
dxt78
Ohio
Reply #5 - May 19th, 2011, 9:19pm
raja.cedt wrote on May 19th, 2011, 11:33am:
hi,
Thanks.
I thought from RobG's post we were assuming equal ID for the NMOS and PMOS.  This would address the "number of electrons" issue you bring up.  The output resistance would then be entirely dependent on lambda, which is a device level parameter that would depend on the doping of various regions right?
raja.cedt
Reply #6 - May 19th, 2011, 11:37pm
hi,
i agree but o/p resistance so called ro is not a device parameter, in fact its derived parameter just to indicate vds effect on current. have you added r0 noise in any simulation? the ans is no because its not physical resister which mainly depends on channel length.
Thanks.
dxt78
Ohio
Reply #7 - May 20th, 2011, 6:41am
raja.cedt wrote on May 19th, 2011, 11:37pm:
hi,
Thanks.
Right I agree it's not a device level parameter.  But we are discussing which has a larger output resistance, NMOS or PMOS.  If the current through each is equal, then aren't differences in output resistances determined solely by lambda?
So I guess the question is what has a small lambda, NMOS or PMOS?  And what determine the lambda of a device?
